Replaceable modules are good and very convenient for self-replacement of the module in case of failure of this module
Shanling M9 Plus - Flagship Android player
- Thread starter Shanling
That’s true. But have you heard of pentaconn jacks (4.4) failing?
- Feb 5, 2005
The decision has been made to move on so it can be said that is that
Nevertheless, audio jacks are a proven reliable technology (6.35mm or 1/4 inch plug since 19th century and 3.5mm plug since the 1950s according to Wikipedia) and devices simply do reliably keep working. A removable plug means 2 points of failure and without the decades and decades of trust that has been earned
Totally support here, removable Jack like conx - men’s worse quality. Hardwired connections are much more reliableThe decision has been made to move on so it can be said that is that
The modules were interesting idea at the time, when 2.5mm was still favored by many and 3.5Pro seemed like a new contender. It was easier to add modules than to make players with 4 different outputs.
Now with industry pretty much settled at simple 3.5mm + 4.4mm combo, the modules are no longer needed.
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
For me it was actually an aesthetics topic.. I am standardized on 4.4mm... So I did not need nor want to see any other gaping holes that only serve to pile up dust on the inside
Stu Paddasso
May I suggest dust plugs for unused outputs.For me it was actually an aesthetics topic.. I am standardized on 4.4mm... So I did not need nor want to see any other gaping holes that only serve to pile up dust on the inside
Extra sockets in the DAP take up a lot of useful space that could be used to place chips and other parts.
- Oct 14, 2013
About time to deal away with modules sockets.
I agree - and only use 4.4mm anymore anyway since I can get a modular cable for $40-$70 that solves the problem anyway for cheaper IEMs that come with 3.5mm standard for review. Most TOTL IEMs come with 4.4mm these days. At the price this will go for, no one is using anything other than 4.4mm with TOTL IEMs (unless they're confused or using 6.35mm for some reason).The modules were interesting idea at the time, when 2.5mm was still favored by many and 3.5Pro seemed like a new contender. It was easier to add modules than to make players with 4 different outputs.
Mhog55
Dream dap for me. I can only imagine how stellar this unit is going to sound. Unfortunately, it's going to be way out of my price range. Kudos to Shanling for keeping me drooling. Some day perhaps.
already know how much it costs?
Mhog55
Nah, don't need to. I was fortunate enough to afford a used M8. Ain't gonna be cheap.already know how much it costs?
It will probably be around $2.5k - $3k like it's predecessor
I think that m9 will cost from $3k and moreIt will probably be around $2.5k - $3k like it's predecessor
Total: 10 (members: 0, guests: 10)
