- Dec 30, 2013
canoman: Huh. The mSD / library update issue sounds pretty odd. I've swapped out cards without issues. Have you tried a factory reset? If not try doing that through the menu first and then again via the reset pinhole if the menu option doesn't fix it.
Just curious, can you just use file browsing instead of the media library? I don't mean permanently. I'm just wondering if you're able to browse files on the M5 that way.
As far as SACD ISO, I don't have any. I typically just use a mix of AAC, MP3, FLAC, and DSD. If you want, you could Dropbox the SACD ISO album, and I could test it out and provide feedback.
Let me know how I can help, and I'll try my best. I've had DAP issues myself (looking straight at you L&P L3), understand your frustration, and want to help!
