Shanling M2 DAP
- Thread starter nmatheis
fourrobert13
FourRobert:
I am using a 200gb card in my M2 also. I have some issues but I am not sure what the root cause may be.
I am having a problem with needing to reset my unit periodically after connecting it to my PC for file transfers and charging. Not related to use as a DAC, as I am not doing that at the moment.
Could be related to the card (though it is a major brand); could be the size of the card, could be a hardware issue, possibly just a firmware bug. I lean to the latter but Shanling has suggested that I swap units The swap is planned when my vendor gets the appropriate color in stock.
Just wanted to put that out there as a caveat. Nothing that is a show stopper as it is easy to reset the unit.
I have hard to reset my X3 Gen II just once since owning it. I know that you are considering the M2 as you have issues with your X3 freezing. I do hang out in the X3 threads also as I still have that unit also.
It is very possible that you will have even more freezes with the M2 unit than with the X3. I certainly do; at least so far. I have reset the M2 about 10 times in the month I have owned it. And maybe you will have no freezes at all with an M2 if my freezing experience is hardware related.
I have had no issues noted with regard to browsing various folders. I do not use playlists.
I really do like the unit; just wanted to share some facts. The sound quality is quite satisfying in my opinion.
My X3 only froze up when trying to use the new fw when I would update the library after flashing the new fw. This was the first time I had to reset any FiiO device I've owned. Went back to 1.4 and no issues. I'm just looking to try something different. FiiO has left a bad taste in my mouth with things they've done and products they've released this past year. So far, from what I've read, your issue with your M2 seems to be just your issue so I'm not to concerned. Now if I start hearing more instances of your issue, then I may reconsider. I'm looking real hard at the M2. It'll be next month before I pick anything up. I know it doesn't have OTG, but I'm kind of past that. I have plenty of micro cards so I can swap them out. Plus I'm keeping the X3 so I'll have options. Thanks for your input.
sledgeharvy
- Aug 11, 2015
And I've literally never had the M2 I'm using freeze, but originalsnuffy and I do have different use cases.
Mine has frozen a handful of times too, but all the other players do the same, so it's apparently just something to deal with.. My iPhone freezes from time to time.. So I personally expect for electronics to freeze up from time to time...
Dickymint
Gents, what are you doing? So far I have neither reset nor had my M2 freeze on me at all. I have added firmware and lots of music files from my Windows laptop without any problems at all. Even my Linux laptop has no problems, have you got the right cards and firmware installed? So far I have had no trouble at all! Sorry, I lie, I had a stutter issue but it turned out to be the 64gb card, I needed to clean to card and re-format it, then reloaded all the same music files back on again. But still didn't need to do a reset.
golov17
Still I do not have any problems with any cards from 16 to 128 Gb, no stuttering, freezing, and rebooting. Everything works fine
- Dec 30, 2013
Shanling: I see the new M5 case on Shenzhen Audio's website. I don't see the new M2 case there, though. When will the new M2 case be available and where can we buy it?
golov17
support, I asked the same question Shenzhen on FB and is still waiting for an answer ..
- Dec 30, 2013
Yes, the link I provided a couple days ago was obviously not the new case, lol
originalsnuffy
I have been doing new conversions of some of my SACD ISO file rips into DSF format. Just loaded Hot Rocks and a few other cuts.
Now, this unit sounds good with a number of file formats, especially hi res PCM.
But I was seriously impressed by the sound with DSD format files. Very close to sitting in the control room listening to a final mix from the original analog tapes.
Wow.
I know that I have mentioned some minor issues with needing to reset the unit from time to time; but then I have to remind myself of the essential goodness of the sound from the device. That far outweighs needed to stick a pin in the device from time to time.
I have been primarily using the LZ-A2 with the JVC spiral dot tips.
Quite yummy.
Wow.
Quite yummy.
bracque
- Apr 27, 2014
You can get the driver from their website: http://www.shanling.com/Product/Detail?id=37372cae0d064c6d8b4f838ef5a6fa57
Let me know if you manage to get it to work.
Thanks. Tried the link but it is all Chinese so no idea what to click. Is there an English version?
http://www.shanling.com/Source/20151010103853_7311.rar
All you will need then is a program to unpack the file (preferably WinRAR).
fourrobert13
Anyone running an amp with the M2? If so, how much more battery life are you getting out of it?
Thanks
Thanks
- Dec 30, 2013
Haven't even wanted to try an amp with M2
Mr Trev
Wow.
Quite yummy.
Didn't you have a X3 from the beginning? You should've been used to paperclipping I would think
- Dec 30, 2013
LOLZ!!!
Yes, I remember FiiO's early DAP days very well. So glad we didn't have to go through that with the Shanling DAPs!
