- Mar 20, 2010
So what happens if/when the Momentum messes up? Lol. Warranties man.... I have to abide by them....
LOVELY job. I want a Momentum sooooo badly.
What was your choice of cable?
h34r: That might have just sold me on the Momentum. Except I have no DIY experience
Very nice! Now all I need is for someone to mod the earcups to a larger size,
A question, why does the jack have four contacts and not three? How are they connected inside?
That is the nature of a balanced connection. Separate ground for each channel instead of a common one. So L+, L-, R+, R-. The mod required removing the internal TRS jack (common ground) and soldering directly to the board that has separate grounds.
So, if the jack has 4 contacts, why did you have to disassemble your headphones, and solder cables inside, instead of just buying such a jack and soldering your cable to that jack?
Ok, so internally it is a female socket with 3-contacts and not 4?
Sorry for that, I should have read more carefully the thread.
I was wondering how did you manage to open the cups?
but what about the mic?!
