Will have the Sony 1ABTs and ws99bt's end of the week to compare with my AEBTs
I very anxiously wait for your comparison on the HC thread. Finally someone else giving his opinion on the ws99bt!
Do not forget to also try them with eq (and also additional bass enhancement things if you have them. They work differently than EQ and tend to make bass denser, more than just boosted) to see how the ws can transform in hulk and get to levels which the other ones can't
I can give you a few tips eventually.
I'm just saying, that in my case, being outside combined with moving my body or my head quickly would produce the problem, with my phone being in my right front pocket.
Indoors, no problems.
yes, i had understood it.
In saying that i have no problems at all, outdoor or indoor is absolutely the same. Smartphone in right pocket or left pocket also the same.
No problems.
Ever.
So my question, should I continue and get the pair pair of the M2 Wireless from Myer or should I go with another high end non-wireless model such as B&O H6 for $466 or B&W P7 for ~$500? and then fill my wireless needs (which if I am honest is mainly for movies & tv shows) with a pair of cheaper wireless ones.
if you knew it's for TV and movies why did you even want to try them?
It's like using a Ferrari to go shopping for a bottle of milk on the corner.
I anyway think that once you find a really good wireless headphone you will want to use them for music too.
So, although you are the only who can know if giving them a try is worth the risk of sending them eventually back (where i personally don't see a risk, because you'll get the money back).
But personally, i would definitely give them a try.
If you'll like the sound and have no issues, you'll have a princess bt headphone there.
