What matters in the end is the result the components produce when working together. With the Essence One Muses Edition I experimented with different combinations of opamps. Higher end opamps sometimes provided a more transparent sound, but could tilt the overall balance in a way that made it unpleasant to listen to. Using a combination of high end and lesser parts delivered an overall sound that hit the right balance where music was produced with the correct balance of impact and fidelity.
I agree that it’s more reassuring to open the box and only see high end parts used. But it’s not certain that’s the best approach in every situation. You’ll have to trust the designer considered the options and made the right choice. I wish Sennheiser were more forthcoming about info on the amp. But that feels typical of a big corporation. Nobody can talk unless it goes through the PR department. For what it’s worth I had the HDVD 800 home at the same time as the SPL Auditor and Violectric V200, and using the same dac the HDVD 800 amp was clearly the best, even single ended. I haven’t had the opportunity to listen to other high end amps like the Taurus or V281. There’s no lack of great alternatives at this price point now.
