Solrighal
- Jan 27, 2005
Okay, I think I'm done buying headphones for awhile LOL
To me HD650 is simply the best value in the market today, espcially in EU where you can buy them new for 300€
I tried/owned almost all existing <1K headphones and I sold all them.
David, have you tried the Fostex T50 with Classical?
Is it worth using the HD 650 balanced? And how much do balanced cables for the HD 650 cost?
If you have a balanced amp, absolutely.
Price is really:
Buy an extra HD650 cable + XLR parts + adapter parts + effort
The difference in amplifier architecture will definitely come into play, however. If you have an amp that does both, usually balanced sounds better because of the design and components. Conversely, if you have an amp that only does SE, it won't automatically sound worse than a balanced amp. IMO.
As far as balanced cables, the HD650 makes it easy to go balanced so lots of options ranging from inexpensive DIY parts, upgraded and more expensive DIY parts, to the official Senn balanced cable or ordering from a cable company. I'm not a DIYer so I paid someone ~$130 for mine (8 ft) and it looks and sounds great, though haven't compared it to other balanced HD650 cables.
