Hmm I wonder how a LCD-3 would complement my HD650s... any thoughts?
I had been listening to the LCD 3 for a year before getting my current 650. The LCD 3 is now sold with no regrets.
Got Grado SR60s in '94, have Senn 650s on my head and the 800s are sitting in the corner.
FWIW, I've seen that comment repeated a number of times, across different threads. I had a chance to listen to the HD 800 at a meet, connected to Glenn OTL amp, and I was impressed. In fact, that listening experience made me take a hard look at getting an OTL amp for my 650s.
So, you really don't use your 800s anymore?
Well, the day has arrived to ask the question: Where do I go from Here?
I love my HD 650s, but post-upgrade of my desktop rig, and a lot of listening, I am finding I want something more. I am discovering a growing collection of music that doesn't sound pleasing with the HD 650s. Basically anything with exaggerated lower-mids becomes fatiguing, at some point.
I was trying to listen to Agnes Obel the other night and some of the tracks were downright painful (Agnes' voice is wonderful, if not a little sibilant, and the piano is a horror-show of bad audio mastering).
Part of my problem may be that I've been listening to my 'phones for at least 5 hours a night (often until 2AM before turning in, and I've wondered if I am just tired and need a break). I've also made a point of keeping the volume low(ish). On the Woo WA3, I rarely dial above 10 o'clock with the HD 650s.
Sometimes switching to my Grado RS2i is like opening a window and breathing fresh air ... until I come across music with elevated higher frequencies, where it doesn't sound like real music anymore, or I am listening to music dominated by warm guitars or vocals, where I really miss the HD 650s.
I've played around with EQ'ing, but what I end up doing in the above cases is just cranking down the mids, at which point I ask myself if I just need different cans.
Do I really need to spend $1,500.00 US for something like an HD 800, or am I better off getting a third pair of mid-tier 'phones and switching between them all, depending on the music?
I suspect anyone that's been a heavy user of the HD 650 has hit a similar point and I am very curious what's a next step that makes sense. Rants/thoughts welcomed.
Can definitely see why based off a quick glance at your music preferences. I briefly auditioned the LCD-3 a few weeks ago and I greatly favored the HD650s for classical tracks. Electronic music on the other hand, initially sounded a bit better for me with the LCD-3 particularly with bass. But they are definitely not worth the $1.6k more, for sure. Hmm, perhaps I should give the Senn amp some thought.
I've read past this and saw the other replies and I'd like to add two points:
1) You are moving up the food chain, gear wise, and you might be at the point where your system is revealing flaws in the quality of recordings you are listening to. Maybe its time to look at the actual music, and not the gear moving it to your ears? It's just a thought that's usually overlooked. The term "the HD650 scales well" might be overused here, but I truly believe that. I'm normally a believer that the cost of amplification and headphone should be similar (like the old home amp to speaker ratios). But, with the HD650 I take zero umbrage with pairing them with an amp that way above the price of these cans. And that leads me to point #2
2) If you feel the desire to go to the HD800, or any other revealing can in the flagship range, its more likely then not going to be a commitment to other near flagship pieces of gear as well. My small amount of personal experience with the HD800 has led me to only want to listen to them through a top notch tube amplifier. I appreciate what they can do through top flight solid state gear (like the GS-X Mk2), but I don't find the sound to be very entertaining.
My 2015 HD650 New Year's resolution is hopefully going to be a near top flight tube amplifier that drives an HD800 nicely. I know that sounds a bit weird, but I never met an amp that nicely drives an HD800 that doesn't also do wonders for an HD650.
After installing Speedball everything came alive. To what people have said about the Speedball, it does become more aggressive and powerful. I wouldn't say there is a ultra huge difference though. It really depends on the song's characteristic and mixing. Some songs you can definitely hear a night and day difference between Crack and Speedball but others are more subtle. Crack gives you clarity and separation for all instruments, gives your cans more power, and delivers vocals as if you're listening to them in the studio. Speedball does the same thing x2, with added warmth on vocals, better instrument separation, clarity, and power. I just bought some pretty good tubes which is on the way so I'm looking forward to seeing how they sound after I replace the stock tubes.
Thanks for your thoughtful response. I've thought about the HE-500s (and they are clearance priced, right now). However, I keep reading that they really need a carefully matched amp and I'm not sure an OTL amp is the ideal pairing.
I need to read-up and ponder, but will take you up on your PM offer for amp considerations.
Congratulations the Crack is a lot of fun and a great introduction to what is possible with diy audio the build manual is very good and easy to follow. There are a several well documented upgrade options that can take the stock Crack to a totally different level. for less than a fancy HD650 aftermarket cable. The new owner of the hot rodded Crack in the pic prefers it to his Meier Corda Classic finding the Crack to have a more natural and realistic sound.
You really should at least consider trying the Senn amp.
Sounds llike a plan
How would you say the Senn amp is, paired with other headphones? The $2k cost is the limit of my budget and there's a lot of other options at that price range.
I have no experience with soldering so a bottle head Crack is out of the question, but are their other good options in the $200-$300 range?
Sounds llike a plan
