cddc
- Dec 7, 2009
Thanks for your response. I will be using the built in amp of the essence for a long while as i'm spending the entire budget on the HD650. If i decide to upgrade the amp in the future i heard the Matrix M-Stage HPA2 is a very good amp for the price.
Essence should be good enough for HD650. You would definitely notice the huge difference between HD650 and OE2.
In terms of upgrade, m-stage is not a bad one...lots of people here also recommend Lyr and Crack around that price range.
