gibosi
- Oct 18, 2012
Yes, I consider rb90002009 to be a very trustworthy seller, and these Reflektors are great tubes for the price.
2nd on this...
If you don't mind diy the Bottlehead Crack is on sale for $199 for one more day only that is $100 off. It is a good amp for the 700's but does need a tube change that will cost a bit more. Still a really great amp.Any suggestions for a good amp and dac for the HD700 at about $400ish total? Mainly listen to genres like synthwave and was possibly looking for a tube amp that could give me some more or deeper bass.
Maybe a Modi 2 + Project Polaris or a Modi 2 and Vali 2?
Also could take some tube suggestions.
And as has been mentioned before, a Little Dot II (or III) is worth considering.
got a used hd700 deal for $250, came with broken cable on right side,replaced it with new one from ebay. A bit loose headband. Okay-ish earpad.
Initial thought after first 2-3 hours; sibilance is definitely real. Unacceptable for any style with vocal. Any concert audio with sub-par recording will annoy the hell out of you with that sibilant hell
I have been experimenting with it for couple of weeks, My impression has been the same,"BUT" for ANY instrumental music,especially jazz and classical. HD700 is the one i would pick up over hd600 or 650 anytime.
What DAC and amp are you using?, a warm SS or hybrid/OTL amp work best with them, like the HD800 you need to select an amp that will pair with its brightness as most who own a HD700 will say the amp selection is important to the enjoyment of these headphones.
