Sennheiser HD 600 Impressions Thread
Mar 16, 2014 at 8:39 AM Post #7,052 of 23,482
The HD600s pair well with the stand.
The stand is called "Fischer Audio: The Curve"
How are you liking the amp!!!
Mar 17, 2014 at 2:49 AM Post #7,054 of 23,482
Hello there,
I just wonder which IEM would suit this badass hd600. Cant really make hd 600 portable due to its size, well now im thinking of IEM on the road. I had own this hd600 for almost 5 years and still amazed with what it can offer. Definitely recommended for new user out there!
Mar 17, 2014 at 3:44 AM Post #7,055 of 23,482
Yadako, go check out the FitEar ToGo 334 IEM. I think it has some good qualities of the HD600 and more but it's priced around 1349 for a universal IEM which is pretty pricey. Like you I'm on the quest to find an IEM that sounds similar, if not better than the HD600. The main reason for this is that I spend more time away from home.
Mar 17, 2014 at 3:55 AM Post #7,057 of 23,482
That's why the HD600 is always at the top of the value/performance ratio list
  but of course I'm not saying that The FitEar TG334 has the excact sound as the HD600. Just that it has a resemblance in sound signature and more.....
Mar 17, 2014 at 4:05 AM Post #7,058 of 23,482
back to my never-ending journey then, really hope some IEM specialist would recommend one in the future
Mar 17, 2014 at 12:34 PM Post #7,062 of 23,482
Yup. I've purchased the HD600 yet again. I can't stay away...
Anyone found a new, budget, solid-state amp that they love? I've owned the E9, E09K, Magni, O2, Headroom Micro, SR71A, Neco Soundlab V3 and Pico Power... Out of all of those, my favs have been the Headroom Micro, SR71A, Neco Soundlab and Pico Power, if that helps. Headroom Micro's are tough to find, E09K is too dark, O2 lacks dynamics (imo), SR71A and Pico Power are too spendy, and V3 is discontinued.
Thanks!
Mar 17, 2014 at 1:45 PM Post #7,064 of 23,482
Your not going to find an iem that sounds like any full sized open back headphone. Completely different designs that can not sound the same. Your question should be about finding a good iem with a good balanced sound in and of itself. You can't compare apples to oranges. So I'd comb the iem reviews for the qualities you like.
Mar 17, 2014 at 1:50 PM Post #7,065 of 23,482
I totally agree, you can find a similar or better sound signature but not the exact same copy. That's why when I mentioned the FitEar TG334 I stressed on the similarities rather than an exact copy. The mid and the highs remind me of the HD600 but the bass on the TG334 is more extended, much deeper and has more slam though at the expense of being less tight than the HD600.
