Giulini's 1970s recording on DG is also something of a benchmark (and the SQ is very good).
Sennheiser HD 600 Impressions Thread
- Thread starter Windsor
madwolfa
Just replaced both drivers (with capsules) in my decade old HD600s with their newest revision (ordered from Sennheiser USA).
That made quite a bit of a difference!
Happy now.
Happy now.
rigodeni
Happy now.
What was wrong with the old ones? Or just wanted to replace them?
madwolfa
I think they've started sounding thin and harsh (too bright), leading to extreme fatigue even on lowest volume. I think it happened after I've tried to remove dust off them some time ago with blowing air (not a good idea)... Also diaphragm looks weird in one of them (dome is elevated and almost touches the capsule/housing) and it was a tad quieter than another, so the stereo imaging was messed up a little. I think it was damaged too. So I've decided to replace them both with latest and greatest Sennheiser has to offer (newest revision). The old ones were the original design (big brass ring) with black baffle plates.
Skolar311
- Apr 14, 2013
Cool man! Wait until they burn in (if they haven't already)
devhen
- May 16, 2012
He's had them for more than 2 hours so they're done burning in. ;p
Tuco1965
- Dec 28, 2012
Heh heh sounds about right.
madwolfa
Left them overnight pumping some dark drum'n'bass, that should do it. Didn't sound horrible from the start, though.
Tuco1965
- Dec 28, 2012
Put on some good tunes and kick back!
madwolfa
Yap, doing "Porcupine Tree - In Absentia (2010 2 x 180 g LP Reissue)" 24/96 FLAC right now!
clohmann
- Sep 4, 2013
I love the HD600s! I think the HD650s show even more finesse and sound tighter with better transients than the 600s. I've been using the now defunct Melos Tubed headphone amp/preamp in my system (SHA-1). I just upgraded my digital front end to the Bryston BDA-1 (wow!)
clohmann
- Sep 4, 2013
My new HD600 has been burn in about 100 hours now and sounds stunning coming through my amp. Prior to the HD600 I had been using the K400 which is fantastic but lacks the conviction and power of the HD600. My Hi-Res Porcupine Tree has never sounded so sweet!
Your HD600 will open up some more after 100 hours of play, esp. in the treble range! LOVE Porcupine Tree - great headphone mixes. Be sure to check out the earlier pre-Atlantic records albums!
clohmann
- Sep 4, 2013
Try at least 100 hours...
clohmann
- Sep 4, 2013
f you don't have a copy - get Porcupine Tree's Stupid Dream. My favorite album from them!I
devhen
- May 16, 2012
Mine didn't change one bit after the first couple of hours and even that period was most likely "brain burn-in". Don't expect them to change.
Total: 7 (members: 0, guests: 7)
