- Feb 5, 2005
New stand so took the opportunity for a photo shoot: http://www.flickr.com/photos/steven2509/sets/72157635297768431/
Five years young this Nov 2013
A question for those of you who use the HD600 in a mixing/referencing/context. Are SS amps the only way to go for this? I currently use an Aphex HeadPod 4 for both critical and casual listening, and I feel like it has done a fairly good job at conserving the 600's relatively neutral sound sig, but I can't help but feel the need to spice things up a bit for casual listening sessions. I have been looking into the Asgard 2 and Valhalla, but I can't shake the feeling that I either have to go with a dry, accurate (SS) amp at the expense of fun, or vise-versa. Should I get a second "fun" amp and keep the HeadPod for critical applications, or is it possible that one amp (Asgard 2?) could do it all? It's worth mentioning that have zero experience with tube amps so I'm not even sure the tube sound is what I want. My favorite attribute of the HD600 is its remarkable ability to reproduce instruments with great realism. My casual listening habits include a great deal of folk/acoustic/bluegrass with a smattering of prog rock. Any thoughts or suggestions greatly appreciated!
Did you have any problems soldering the the stock cable to the XLR? I heard that Sennheiser tries to prevent it by making it difficult by putting some kind of coating on it. What kind of solder did you use? Can you A/B balanced vs SE cable on your amp? What are the differences? Are they night and day? I'm assuming the difference is substantial. Sorry about the 20 questions.
It also works really well with deephouse and progressive house. The often submerged and dreamy bass together with the clean and rich mids of the genre can be superb with the 600 (as long as the recording is decent, which is not that big of a deal in this age).
Is anybody running their HD600's with the schiit magni and modi stack? If so what difference to the SQ did it make? Are you a happy camper with them?
To add on to what I posted earlier, I tried using my phone > iCan and then tried all the combinations of the iCan sound tweaks, the most "stressful" one being lv3 3D sound with lv3 bass boost(~+10db). Surprisingly, there was no distortion that I could make out with this setup, and I quite enjoyed it with some songs I suspect that using a tube buffer adds some distortion to the signal, which can be amplified further if u use a bass boost. However if your source and amp are solid states, the HD600s can probably take even +10db bass boost without significant sound degradtion.
A bass boost and soundstage enhancer like the ones on the iCan would be nice - I wish I had them on my amps. I would probably use the level 1 bass boost - I'm happy with the amount of midbass on the HD600, but subbass extension could be better.
