thelewis323
- Jul 14, 2011
I'm thinking that I may just order the cable and do the modification myself. It would end up being about half the cost if I were to do it that way. I'm pretty proficient at soldering, but the only thing I'm worried about is what happened to swbf2cheater's set of cans. It seemed that he blew out his drivers by trying different 2.5mm adapters. I would hate for that to happen if I got the pin configuration wrong. We shall see. I should probably buy the headsets first and THEN worry about the cabling. Haha. Thanks for your help.
yepp but the headphone first
And if you get the stock cable you shouldn't be messing with the 2.5mm end, you just trim the cable and change the 6.3mm end to 3.5
![bigsmile_face.gif](http://files.head-fi.org/images/smilies/bigsmile_face.gif)
If you have the skills to do it it should be all good, perhaps when you take off the 6.3mm jack make a note of the wiring
Good luck!
