pdrm360
- Jul 2, 2013
You can just use the preouts on the Asgard (or Lyr) to connect the other amp.
I'm an idiot.
No, if you use the preamp out, you will merge the amps sound signatures.
I'm an idiot.
Wait, isn't that the entire point of a preamp out? To push out a signal previous to the amp?
You can check this with your Lyr, connect your E09k to the preamp output of the Lyr and enjoy the beautiful tubey sound.
What's the point of the preamp out then?
Any additional device will "damage" the musical signal somewhat. A switch or even an RCA "Y" will leave its signature as well. The question is how audible (if at all) will each method be.
Ok, so this goes back to my original question then. Is there a sexier way to switch between a Lyr and Asgard when connecting them to a Bifrost besides changing wired connections or some plasticy RCA switch? A triple-stack if you wish.
