- Dec 17, 2012
About to order mine, just sold some stuff to get it...
I started looking at how small the A2's were and how big the A5+'s were and that did it for me. A2's. There doesn't seem to be a lot like them.
I'm stoked about your remarks how the Lyr works with powered speakers.
I have inputs to USB and optical, and they're both being fed by the laptop simultaneously quite often, USB for the computer and Internet sounds, optical mainly for foobar. This is quite a boon for me as before the Bifrost, I could only output from the laptop with only USB to the uDac2, and when foobar was playing through WASAPI, sometimes video players (including Netflix) in browsers would crash or report error with sound (as foobar took over the sound stream with exclusivity). But with the Bifrost, you can do what you're asking (though I can't be certain of coaxial as I've never tried that out).
On my Gateway PC I have USB and HMDI ports availlable, but not coaxial and optical SPDIF ports. Does that mean I would have to purchase the spendier model with the USB option? After reading many of the posts in this thread, it looks to me like SPDIF is preferred....
One if these would do the job.
http://www.amazon.co.uk/ViewHD-Premium-Audio-Extractor-Converter/dp/B00AHS8LD8/ref=sr_1_5?ie=UTF8&qid=1362239398&sr=8-5
Basically turns your HDMI port into HDMI + SPDIF.
You'll save a fortune if you get that instead of the USB version of the DAC.
Not directly stated, but I assume the Statement amp will be priced pretty much right on the price of the DAC?
It's been stated that statement gear will run double of the mid-tier balanced Schiit. So yes, approximately.
And pricing could be subject to change...
It will not use the same family of tubes as Lyr.
But that was also kind of subject to change per Jason's words.
Thanks for pointing that out Paradoxper. I was under the impression that it was going to be solid state. Whoops!
