preproman
- Mar 16, 2011
Excuse me - but here is your SE out right here.
Nice review. What turns me off products like the Bryston is the lack of thought that seems to have gone into the design. What kills it for me is.
1. A balance control that appears to be non defeatable. What is the point of a balance control unless you happen to be using airline quality headphones that have severe channel imbalance? How much better a simplified Bryston with no balance control would sound I can only guess.
2. No line output.... Come on, for the kind of money they charge for that thing, could they not have splurged on at least one output?
3. No single ended headphone output. (Ok, so this amp is meant for only the very best cans with balanced cables and you can take your single ended cans elsewhere. Wait a minute, in that case, what is the balance control doing on that thing? You do NOT need that with high end phones, unless perhaps your ears our out of whack relative to each other.)
Enjoy the Bryston
1. I've asked this question myself without getting any answer. But remember BHA-1 is also for studio use, maybe if you're monitoring a rough mix or something it could be handy. Or listen to some 60s vinyl... I guess the balance control doesn't degrade SQ, otherwise they wouldn't have put it there.
2. There is a line output now, their homepage isn't updated yet though. Male XLR pre out at the back connected in parallell with the front XLRs, i.e. after volume control.
3. What are you talking about? There are 2 x 3 pole XLRs, 4 pole XLR + a standard 1/4" SE output on the front, always has been. Check the photo. Are you mixing this up with Mjolnir? Check facts before posting.
Edit: I'm so slow answering, sorry...
"The price on the BHA-1 will be going up approximately 10% but it will provide our customers with a much more versatile product."
Very interesting. I guess they designed the BHA-1 on a Friday. Anyway, nice to see they are improving it. I bet they will loose the balance control sooner or later. Does it have some sort of bypass if it is set to the center or does the audio signal always have to go through the balance pot?
Basically you started ragging on a product you hadn't investigated properly and now are finding all of your information wrong or out of date.
