joeexp
- Aug 5, 2014
Definitely get the Gumby, even if you have to wait longer. The price difference is justified. I tried both and find that decision very easy. ...
Does anyone here have any real life experience with the Gungnir multi-bit vs. the Resonessence Labs Concero HD? I own the Concero HD and am now considering the Gungnir MB. Any input is appreciated. Thanks.
The issue isn't balanced or unbalanced - It's just that the Gumby is better on retrieving detail.
However the Bimby is a fine machine and is a fantastic bargain if you want to venture in to the realm of R2R Dacs.
It's easy. If you can afford a Gungnir Multibit, get it. If you can't, but you can afford a Bitfrost Multibit, then get that one.
LOL That is what I'm on the fence about. Schiit Audio puts quality into all the products and I like their ethic that is way I'm staying with them. I guess I don't fully understand R2R Dacs though. So the Bifrost Multibit is R2R and the Gungnir is not. Correct?
Yes sir, I'm leaning toward the Gungnir just wanted a comparison of what they sound like so I might be able to save a little money. I have been all over the internet looking for comparisons on sound and I come up with one or the other but never really a comparison. I have read the differences on delta sigma compared to multibit and choose to go the multibit which seems to have more detail to the music. From what I have read. Just curious the sound between these two one from the other. It seems they my be pretty close to SQ. Tonal qualities maybe different.
Some have said the Gumby and Bimby in SE mode sound similar. I cannot confirm or deny this. but here are a few posts that may help. I searched for his detailed comparison but could not find it. I have the Bimby because at this point there is no plans to going Balanced . From what I read some say that the Bimby and Gumby sound similar In and SE config with the gumby edging out in some details but in balanced mode the Gumby Grew its horns.. er I mean sprouted wings.
Atomicbob has/ the Yggy, Bimby and Gumby. Look through his posts, he has also done some great work taking measurements and posting them. He seems to really enjoy the Bimby. The last I read Mike Moffat was using the Bimby and Vali 2 for one of his listening stations. (That's a great combo by the way.)
http://www.head-fi.org/t/785367/bifrost-mb-technical-measurements
http://www.head-fi.org/t/785365/gungnir-mb-technical-measurements
http://www.head-fi.org/t/785369/yggdrasil-gungnir-mb-bifrost-mb-a-terse-ribald-comparison#post_12015806
http://www.head-fi.org/t/785369/yggdrasil-gungnir-mb-bifrost-mb-a-terse-ribald-comparison#post_12012998
Thanks to all of you really helps out. I had looked ALL OVER the net reading everything I could. Including the differences between DS and Multibit or R2R, as it is also called. The details and musical aspect of multibit is the reason why I want to upgrade. Also the reason I went with the headphones I did. Just did not have enough money to spend a grand on headphones then a grand on a dac. So I read all the reviews on here and decided to go with the 400i. As far as a dac I figured I would stick with something I know. I have had my Magni 2 U for almost 3 years using it off my sound card then got the Modi 2 U. All I have done I have seen improvement. Improvement in detail and channel separation mostly but still improvement. So when I read that a multibit dac brings even more out I figured I would take my tax refund and save a little and jump to the next level. Always wished for equipment like this when I was young but money seemed to slip through my fingers. Partying takes money when one is young and foolish. I think I will go ahead and get the Gungnir MB. Have to wait a little but it will be worth it. Rather do that than set and wonder what it would have sounded like. The quality of sound I have now is better than I have ever had. With speakers or headphones from the past. The 400i and M&M stack is like a open window compared to a closed window. I can't wait to here the Gungnir MB if it take things to another level. Wow.
