TS0711
- Sep 5, 2010
No disrespect but the Freya is the weak link in your chain. I'm a fan fan of Dynaudio, having owned the Special 25's since they were first released. Not sure what Carver you have but new caps can't hurt depending on it's age.Well, right now I have the Freya hooked up using some GE NOS Tubes to my Carver…running Dynaudio Contour 20 Speakers. "To me" it sounds fantastic!…The reason I want the Kinki Monoblocs is that I want to hear my set-up thru a modern high-quality amp. Also…I want to take my Carver to be serviced… I think. It has its original capacitors in it and they sound fine (which most reviewers say is not possible. THEY'RE WRONG!)…but I think I should have them replaced, the volume pots cleaned (or replaced), the contacts cleaned and any upgrades done that my tech seems to think are relevant. He has a 4-5 month turnaround time, so I need the new amps so that I have tunes!
I own the original Freya and swapped it out for my passive Bent Audio TVC (which was gathering dust in a closet), and there was no going back. That said I use antique VTL compact 100's with original Mullard EL34's feeding Marten Design Dukes... Also interconnects matter... Get yourself speaker cables and interconnects from Crimson Audio and be done with it.
Unsolicited advise from an old guy
![Headphone :headphones: 🎧](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f3a7.png)
