sceleratus
Previously known as Iamnothim
- Mar 31, 2013
What that is telling me is there is an external problem that causes your Bifrost (probably trans) to hum.
Why?
Because an external device fixes the problem. It doesn't fix the Bifrost, it gives it clean current. I know that sounds stupid.
It's great that you have it suppressed, but I'd like you to find the source and fix it.
Thanks guys! What I have is one of those 4 outlet Tripp Lite Isobars, with the source, amp, and DAC plugged into it.
If I take the Bitfrost out of the equation and use the DAC's of the source (Pioneer or Onkyo SACD players, 2V out) and connect by analog to either a Lyr, Asgard, or Little Dot Mk III, the amps are quiet (except for the Lyr which is very slightly noisy at full volume).
If I use the optical or coax (doesn't matter which) out of the source and connect it to the Bitfrost, I get prominent hum after about 12 o'clock (on any of the amps), although I can detect it lower on the volume knob.
The Bitfrost (in combination with any of the amps) appears to be the culprit.
I've tried powering straight into the wall, other outlets, an APC H10 line conditioner, directional and/or different rca cables.
Nothing has stopped it except the cheater plug.
BUT now, after a trip to Guitar Center, I am the proud owner of a $75 HumX (yes my @$$ hurts) which is performing the same as the cheater plug. Didn't really think I'd have to buy an additional piece of gear after dumping a boatload of currency into Schiit gear.
Why?
