energie
- Sep 19, 2008
another question....is 9505 compatible with fiio e07k?
thanks
thanks
Thinking of getting an S4 or HTC one but really concerned about this issue. I've got a pair of Fischer Audio DBA-02 mkii's which are 43ohms but i've heard that the impedance can move around.
Has anyone got a graph for the dba02 mkii? I can't find one anywhere. Or even better, has anyone heard the s4 with these headphones?
Both Samsung Galaxy S4 versions did greatly in our audio quality test. They both had excellently clean output in both testing scenarios and despite the fact that they use different audio chips, their output is quite hard to tell apart.
The Qualcomm-powered Samsung I9505 Galaxy S4 had the tinniest of edges in the headphones-plugged-in testing scenario, exhibiting slightly cleaner audio output, but we doubt anyone will be able tohear the difference. The Exynos-packing I9500 Galaxy S4 makes up for it with an advantage that's a bit easier to hear on your own - slightly higher maximum volume levels.
No matter which of the versions of the Samsung flagship you choose, you will be more than happy with its output and certainly we wouldn't advise you to make your selection based on the audio output - it's just that it's too close to call here.
And here go the results so you can see for yourselves.
[size=inherit] [tr][size=inherit] [td] [size=inherit]Test
[/size][/td] [td] [size=inherit]Frequency response[/size][/td] [td] [size=inherit]Noise level[/size][/td] [td] [size=inherit]Dynamic range[/size][/td] [td] [size=inherit]THD[/size][/td] [td] [size=inherit]IMD + Noise[/size][/td] [td] [size=inherit]Stereo crosstalk[/size][/td] [/size][/tr] [tr][size=inherit] [td] [size=inherit]Samsung I9500 Galaxy S4[/size][/td] [td] +0.03, -0.04[/td] [td] -94.5[/td] [td] 93.4[/td] [td] 0.0036[/td] [td] 0.016[/td] [td] -93.0[/td] [/size][/tr] [tr][size=inherit] [td] [size=inherit]Samsung I9500 Galaxy S4 (headphones attached)[/size][/td] [td] +0.03, -0.02[/td] [td] -93.0[/td] [td] 92.9[/td] [td] 0.0084[/td] [td] 0.062[/td] [td] -77.5[/td] [/size][/tr] [tr][size=inherit] [td] [size=inherit]Samsung I9505 Galaxy S4[/size][/td] [td] +0.03, -0.08[/td] [td] -95.9[/td] [td] 93.2[/td] [td] 0.0030[/td] [td] 0.0092[/td] [td] -96.4[/td] [/size][/tr] [tr][size=inherit] [td] [size=inherit]Samsung I9505 Galaxy S4 (headphones attached)[/size][/td] [td] +0.03, -0.08[/td] [td] -96.0[/td] [td] 93.3[/td] [td] 0.0031[/td] [td] 0.089[/td] [td] -95.5[/td] [/size][/tr] [/size]
thanks
Sadly no. I cannot get my i9505 to work with my e07k. People have tried different roms as well without success. The only way it currently works is using the USB audio recorder pro app. However the app is not free, it does not play mp3s, it'll only play wav, flac, ogg and aiff from what I can tell.
Checked out a S4 in a shop today - it drove my Blox M2C (30 ohm / 110 dm/mW) very nicely at 1/3 volume and also my (unmodded) Fostex T50RP -(50ohm / 98dm/mW) - quite OK at 80% volume. I only heard sample track from Samsung on the stock player, so cannot really comment on the SQ except it sounded punchy and not lacking in power, it could play louder my ears tolerate, and I didn't notice any clipping or disortion.
