UnityIsPower
GR07 BE, iPhone 4, what I gotado?
Thanks Joe.
I've been using V4A for awhile now, and it's amazing, can't wait for the next version to come out with more DDC profiles.
I'm curious, what made you use a model that hasn't been released yet for this challenge as opposed to an already known FOTM Chinese IEM. What was it about the MH412 that stood out to you? Also what's the expected MSRP when it launches?
James - thank you for the tutorial and music files for evaluating IEMs, I learned a lot by reading your post.
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
*Please note that FiiO is not in any way, shape or form related with Somic and this is just something I've been playing with in my off time. James, I thought the idea of having you start the thread was to take me off the spotlight for this event? :stares hard at James:
Well, here's something to ease your mind... I met two local audio enthusiasts earlier today, let them have a listen to the MH412+V4A combo, and one of them ended up saying that he actually preferred the stock sound. If the event continues in this vein, it may take the two of us off the spotlight sooner than we think.
I'm trying to get V4A to work on my Nexus 5, and I'm having issues. It seems to work when I put V4A into FX compatible mode; the eq and other settings work fine, but when using convolver and choosing the KC06 48k.irs file I don't hear a difference. Is it that slight? It really sounds like nothing at all changes. If, however, I change to the the MH1(C).irs file then I hear a big change. BUT, when I change back to the KC06.irs file from the MH1(C).irs file there is no change. It seems that the MH1(C).irs file remains implemented no matter which irs file I choose until I turn off V4A's master switch. This leads me to believe there's an issue with the KC06 irs files? I've used both the KC06 48k file and the 44k file with the same results.
This is quite interesting what you have here guys.
Looking forward to your impressions/reviews.
@Joe Bloggs
will it matter if I own a different android device?
I have the HTC one but I honestly don't like the sound from its onboard dac.
Using the JDSlabs C5D however is a very nice paring with the HTC.
Are all the IRS files placed in the Viper4Android\Kernel\Kernel folder (and not a subfolder thereof)?
BTW, here's a custom build of the latest firmware that makes switching between profiles more reliable.
http://forum.xda-developers.com/showthread.php?p=52019235#post52019235
Not sure that makes any difference to your current problem but it's the build I'm using right now and the build on james' S3
If you still don't hear anything from the KC06 irs, try renaming them. If it still doesn't work I can tweak the files a bit for you.
Also, what music player are you using? Note that if using poweramp, you need to disable Direct Volume Control. There's also a MusicFX button which I'm not sure whether it should be on or off, but will make a difference to V4A working with compatible mode off (which is the more desired situation)
Assuming you get the software working and choose the IRS file with the sample rate corresponding to your phone's operating sample rate, I'd say the particular phone used with these dynamic IEMs makes not much difference, I'd say 5-10%. That 5-10% mostly being down to any resampling noise artifacts that may exist.
Update: it works! Joe that link you posted worked great. There is a clear improvement in the KC06. Wow. Bass is less emphasized, mids are more forward, and treble isn't as peaky. I'm really really liking this.
Would you consider doing one for the ER4S? I will gladly donate! As of now I'm just upping the bass by ~7dB at 40Hz.
