happysappy
- Aug 23, 2016
@happysappy
First of all, it seems like ATH-IM70's right side's sound filter is clogged. If it is the filter, there are ways to fix this.
Second, it sounds like the output impedance of your Surface Pro 4 is very high. The ATH-IM02 does not have a flat impedance response but actually an upwards tilting impedance curve shape in the highs, so when it is connected to a high impedance source, you would experience a brighter and more metallic sound.
You could either evenly reduce the treble using an EQ or get a DAC/headphone amplifier with low output impedance. Matching models would be the Leckerton UHA-4, JDS C5D/C5 (the latter if you only want to use it as a pure amp from your phone's headphone out), FiiO E17k/Q1 or A1 if you only want a cheap low impedance amp-only device.
I will have to research on cleaning the sound filter as I have never done this before. I apparently don't have EQ powers as most of the time they just sound muddy and ruin the experience. I'm probably doing it wrong, but I never bother with it.
I have the FiiO E07k and E06, but I may get the JDS C5D in the future to better match this IEM. Or the FiiO E17k or K1 if I decide to save money. Thank you so much for your suggestions!
