After almost two years of using the Nuforce iDo as source/transport for my bedside rig, I got the opportunity to get the Nuforce DAC-80 for a bargain.
Now it's two weeks that I'm using it in the following set-up:
iPad - Apple CCK - DAC-80 - Little Dot MkIII tube amp - HD800
To be honest, the DAC-80 in this setup is a great device but not perfect. The volume control is bothering me a bit. When using the remote all is fine, except that you hear the volume increase in steps. The lowest volume level is quite high before moving to silence. Plus, the position of the volume control seems to lead to a fixed level. So touching the volume control can mean jumping to a level much higher or lower than what you were listening to.
Anyways, the upgrade is nice but I don't really mind switching back to the iDo.
So far for my bedside rig. The DAC-80 is nice but not a must.
I then moved the DAC-80 to the living room, where I have the Nuforce AVP-18 connected to two Quad 405 power amps bi wired to a pair of Vifa self built speakers. I used to have a 5.0 setup but gave up on that when I moved and was too lazy to pull all the cables and frankly, I don't miss all this multi speaker stuff, my heart is in Hifi.
Anyhow, I decided as an experiment to disconnect the AVP and put the DAC-80 instead in between my source (connected through Optical SPDIF) and my Quad's. Oh my... what a sound! It is maybe off topic on head-fi, but as a DAC/Preamp the DAC-80 is absolutely superb! The definition is perfect, the bass deep and controlled and above all, the soundstage is super impressive. Where the AVP-18 already impressed me, by a wide soundstage beyond my speakers and excellent placement, the DAC-80 makes it 3D. Apart from the horizontal plane through the speakers, the DAC-80 makes instruments and voices also come forward or move backwards. I almost had tears in my eyes when listening to my favorite tracks.
So, where as a DAC in my bedside rig driving my HD800 the DAC-80 didn't really impress me, as a preamp in my Hifi setup it absolutely did! I'm afraid my AVP-18 will go on sale.
The only issue is the lack of sources on the DAC-80. If anyone has a tip on a DAC of similar quality that can be used as a preamp and has a bit more sources, then I'd be interested. I'm looking at the NAD M51 but not sure if it will impress me like the DAC-80 does...
