bergman2
- Aug 1, 2007
Maniac,
After just reading this entire head-fi thread I have a few questions...I am cobbling together a little system via the computer---i have an m-audio firewire (that I'm using as a dac via firewire from my computer) and an earmax pro tube amp (handling amp duties) which goes to my recabled hp's (595's and sa5000's)...i auditioned a few tube dacs but none of them exhibited good synergy with the tubiness of the earmax pro (horribly mushy), so i'm thinking a good non-tube dac would balance better with the tubiness of the earmax...anyway, your products seem to be good (from the reviews I read) AND within my budget...BUT I can't decide which one is better for my purposes...is the "spdif-coax out" on my m-audio firewire of a good enough quality to pipe the signal to the "input spdif-coax" of the 131...if not i would probably be better off with the 151...second, how do i go about getting that new, better chip upgrade thats in the 151 put into the 131 if i order it....lastly, can i get the $10 off if i order straight thru you (as i remember reading in the forum)...thanks in advance
