Audioexcels
- May 31, 2006
I think John originally thought that attenuators wouldn't be necessary with the MK3 version, but even with the output voltage now within the correct S/Pdif spec, the attenuators may still be able to reduce cable reflections and improve performance.
I know if I owned the MKIII, the amount of money into one warrants trial and error regardless. These attenuators are so cheap one should definitely experiment regardless of what was said about not having to use one so long as it doesn't cause harm (which of course it will not). Drez is a good example of one that decided to trial/error with the attenuators and has found improvement with his MKIII already! I say give it a go, or ya'll never know
But yes, I know John's original intention was to produce a perfect device that would not require anything, and it may be how it is for his own testing system that he builds these on, but may not be the same as someone like Drez or another person's system.
