Happy Camper
I'm betting things change. Leave it running for long periods to get ran in at moderate volumes. The 500s shape up after maybe 50 hrs. The bass firms nicely.
Using a MacBook Air to rDac to fiio E9 using mostly spotify. I don't know what is going on. But tomorrow I am getting the Audiolab M-Dac and will see if it makes a difference. Have spent so much money on this stuff my pocket is empty now. So yes someone would be getting a bargain if things are the same after a week.
Thanks all for the replies. I am going to stick to it as suggested. Even in the manual it says give it 150hrs to settle down.
Mine took ~48 hours, not sure if that is burn-in, mental burn-in, or velour pad burn-in, or a combination of any mentioned. Most noticable is sound becoming more open, bass less flabby.
Be sure to use the velour pad too. Pleather pad sounds way too muffled - not sure why Hifiman choose it to be the default pad.
Just got these and mmm they are good. Thinking about trying the velour pads, but I've never changed ear pads before and quite frankly I'm terrified. Any advice?
Cut a small rectangle from a random hard plastic gift/credit card, of about 5cm x 1cm. Trim the corners of the rectangle cutout so that they are rounded off. Use that to pop in/out the tabs of the mounting ring that secure the earpads onto the headphones.
There are four such tabs, once you pop out two adjacent tabs out of those four with the card cutout, the earpad comes right off.
There are actually 3 items
1) phones
2) plastic slot to mount the pleather/velour pads
3) pleather/velour pads
It would be good if they can provide 2 plastic slot. Easier for everyone to attach and de-attach the 2 different pads.
Cheers.
They are being powered by the Audiolab M-Dac which in it self a great unit. Time to get rid of my rPac, FiioE9K, and Akg702 and maybe the HD650.
