Here are some measurement from my homemade rig. The interesting bit to me is actually how closely Atrio M5 rev2 and MG7 resemble each other in FR curve and the impedance is a few ohm in difference, yet the two give me really different impression in sound. G10 overall has the same Future Sonics house sound, but bassier and smoother. A proper bass monster, I guess.
[REVIEW] Future Sonics Spectrum Series: G10 and impressions thread
- Thread starter Kunlun
Kunlun
- Jan 25, 2010
FutureSonics.com has a special discount on the G10 until 11/30!
This is a nice chance to pick up a set of these for a good discount.
Just use the promo code FSG10 at checkout for 20% off.
- Aug 9, 2006
Well, it's long after the fact, but finally I've published my review of the G10: Future Sonics G10: bassy done right.
myemaildw
- Jun 10, 2014
Another con for G-10 is its impedance and sensitivity. I don't want to be mandated to carry an amp. in my pocket on the go i just don't have room for it.
It looks like I have to reluctantly and secretly keep on collecting savings for the
[COLOR=5A5A5A]Aurisonic ASG-2.5[/COLOR]
2.5 also needs an amp
myemaildw
- Jun 10, 2014
MrBackup
- Jul 2, 2015
I am interested in this in-ear. I dislike the use of plastic in the manufacture of casings.
I have Hifiman RE-600, RHA T20 and the JVC FXT-90. Is this G10 greater than what I already have?
- Aug 14, 2014
I think you should be set with the T20, much more versatile than the G10. You should only get the G10 only if you're craving for more bass especially in the sub-bass region
Agreed. T20 is easily an level above G10.
Raketen
- Apr 5, 2010
Uggh, G10's getting on so nicely w/ AK Jr. I might have to forgive it for being a laggy, hand-stabby half-bak....
markhayes0338
- Dec 4, 2015
I currently have the RHA T20's but I'm thinking about sending them back for the G10's. Personally, I can't seem to get the fit of the T20's comfortable. I'm using Comply tips now and they are comfortable, but at the office where I use them, I'm always pulling them in and out and having to compress the tips every time prior to inserting. It gets old after 4 or 5 times of doing so. That is why I like silicon tips, but none of the included RHA tips isolate very well for me and the retention is terrible.
I like the overall sound quality of the T20's but could use more low end, personally. That is why I started looking at the G10's. If that is going to sacrifice the overall sound quality then I'm not sure that is the step I want to take. Do you have any suggestions for my predicament? Thanks!
My first suggestion is that you should try other aftermarket silicone eartips with your T20 first. If you have problem with common eartips design, then there might be a good chance you will run into the same problem with other IEM as well. Like all Future Sonics's universal, the G10 comes with a tri-flanges and it really does require some getting used to as it is not really the most comfortable eartips you will find.
Also, won't hurt to bend the T20's cable a bit more (the part that is closest to the earpiece that looks to have some memory wire inside) so it will better fit the curve of your outer ears. Don't forget to use the chin slider / cable guide as well. Last item to check is the eartips size - might worth a try to use the eartips that is one size larger / smaller to see if they will fit your ear well. Also worth noting is, Comply does have the TS series, which doesn't require any compression before inserting.
As I said before, G10 (and Future Sonics' universal in general) doesn't really have that great a fit but rather require some getting used to. So if fit is the reason why you want to chance IEM, I am not sure G10 will be the top of the choice. Of course, fit is also a very personal thing so it might work for you. Just that we won't know for sure till you tried it.
markhayes0338
- Dec 4, 2015
Thanks for the information. I've had 3 pair of Shure and a pair of Klipsch in the past and I had never had a problem with fit. Double or triple flange tip and shove them in. They were always pretty comfortable and didn't have any issues. The T20 seem like the angle of the nozzle just isn't enough when compared to other brands. It is almost a right angle instead of closer to 45°. I used shure's on stage performing for 5-6 years and never had these issues. Oh well...
Sent from my Moto X Pure
Raketen
- Apr 5, 2010
I loathe multi-flange tips, but the foams are good and with the short single-flange Westone Star tips I find the G10 very comfortable (among the most comfortable of the inears i've tried) and decently isolating, after a few hours I really appreciate how light they are as well.
Kunlun
- Jan 25, 2010
Good review, Nathan. Sorry I missed it earlier.
