The ASG-2 I tried belongs to a nearby audio retail store, which carries a demo set. If the set is really faulty, It would definitely left a lot of bad impressions on the ASG-2.
You can't find them in Singapore, so either have to purchase then online from MusicaAcoustic or Ortofon Europe. Bare in mind though that the Ortofon tips are smaller than normal tips. So if you use M size stock tips, most likely you'll be using L size Ortofon
After doing some cable change I can say that the stock cable supplied with ASG-2 is hurting asg-2 greatly! I have a cheap silver plated copper with 6 cores and compared to the stock the bass becomes a light tighter and there is a noticeable improvement on how the dynamic driver is performing. Dynamic drivers always require a good amount of power for them to sound best.
I am reading about various cables I think asg-2 deserve a better cable than what it is provided with them.
My thought also bro. When I tried a demo set which belongs to the local distributor back in May, the treble was almost non-existence and the bass was just to overpowering.
So when I tried another demo set at the local audio store set that you also tried recently and my finding remains the same, it struck me that maybe they are just tuned that way.
