kwatch
- Aug 2, 2012
I just ordered Audioengine D1 from Crutchfield. Do I have to have a good sound card in order to take a full advantage of D1? I'll be connecting it to a computer via USB cable.
The point of D1 is to bypass the built in sound card. The D1 IS a sound card. The way it works is that the music is sent digitally in 1's and 0's through the USB wire into the D1, then inside the D1, the digital files are converted to an analog form (current) that comes out of the headphone jack through your headphone cable into the earcup where it converts into sound (vibrations) hence why it's called a DAC (Digital to Analog Converter).....Unless you were talking about jitter related topics with transport issues, but I'm guessing not.
You're welcome
I can remove the sound card made by Creative Labs from desktop computer if I want, right?
I would not recommend the D1 for a headphone with an impedance of 40 ohms. The reason is that the D1 headphone amp has a 10 ohm output. Using the 1/8 rule, you should only use headphones that are > 80 ohms for optimal sound quality.
I don't have a problem using the D1 with low impedance phones like the D7000, so Pro 750 might be just fine. Some say the 10 ohm output impedance would cause a bump in the phone's mid-bass, but I'm not sure that's all that noticeable enough to make a difference.
Hi there...
I was considering buying this unit for two uses:
1. To power a pair of Audioengine 2 speakers
2. To power my Audio Technica ATH M50 headphones
Aside from the fact that the headphone power ratio isn't optimal (I can get over this), I'm curious as to how the volume knob would work in this setup. Can anyone enlighten me?
I've been used to an outboard audio interface where headphone and speaker levels can be controlled independently. In this setup, would it control both outs at the same time, or would it only be possible to use one at any given time?
Confused...
George - Audioengine did respond back very quickly and sent out a replacement the same time that I sent my faulty one back. Their customer service is top notch and the replacement works great. I could not be any happier with the quality of sound from the D1. The instruments sound airy and very focused. I think this has a lot to do with the high-end AKM DAC in it. Cheers. -Norm
Hopefully this clears things up a little bit for you.
