jinx20001
- Jul 4, 2007
i see, i meant in general build, as in a thin cable and tiny earpeices is a recipe for disaster if not looked after. but your right again the earphones are durable if treated correctly. as sound quality goes im not a fan of ety so thats my reason for my comments. your also right about the se530 vs triple fi, its all about personal experiences and if you had trouble with the earphones i dont blame you for marking them down, i personally find the se530 much easier to fit, i found the memory wire of triple fi to be more troublesome than helpful, always having to adjust the memory wire to fit around my ear again everytime wheras the se530 you just have to pull up the cable tie in the middle and they stay flush behind the ear hence my reasoning for saying the se530 are much better thought out, but yeh as i said you have done a great job and enjoyed reading through it, thanks!
x2 trust me i agree, i said i didnt like the build because in theory the thin rubbery cables and simple plastic housing is asking for trouble, but yeh as i just said i agree that earphones in general can last as long as you like really when treated correctly
Originally Posted by ClieOS /img/forum/go_quote.gif I think I should offer a bit of explanation on how I rated the value of these IEM. There are two factors that I consider: The price I paid for and the price offered by online official dealers (who carry both), like Amazon, Buy.com, and a few of our sponsors. eBay and unofficial dealer are not in consideration. From all the price I gathered, SE530 is still more expensive than TF10, although in varying degrees across different sites. SE530's earpiece is more comfortable to wear, but the heavy cable (w/ no memory wire) is a downside. TF10's cable is stiffer in comparison, but at least the memory wire holds it behind the ear effortlessly. Because of the different in weight and memory wire, I often find myself in need of adjusting SE530 earpiece to give the best fit, and that reduce the overall comfort. If SE530 comes with UM2's cable (which is light enough not to drag and soft enough to confirm to ear w/o memory wire), than perhaps I will rate it higher than TF10. As for SQ, I have given my explanation of why I rated SE530 down in my review. Personal musical preference has a big role in determine why sounds the best, and as I said before, I did not deny that I prefer TF10 over SE530 because SE530 often sounds duller in comparison. My ER6i has seen active duty for a period of two years w/o giving me any problem, thus I didn't give it a poor rating on build quality. Hope these explanation help. |
Originally Posted by synaesthetic /img/forum/go_quote.gif I honestly have NO IDEA how you people destroy ER-6i so fast! I had a pair for four years that were totally abused--they were left out where cats could grab them and play with them, they were stuffed in pockets, in purses, wrapped around MP3 players, used without filters for most of those four years and "worst" of all every time I pulled them out of my ears I grabbed the wires instead of the earphones. And they still worked when I gave them away to a friend after buying ER-4P, and they still work for him even now, six months later. So really I do not at all understand how people can go through ER-6i so fast unless you guys are just unbelievably hard on your equipment. |
