Hey, I saw your amp before! That tall tube sure is neat-o! Your mods look cool too, learning DIY skills is like a cost I can't afford right now though, personally.
The little dot I+ was highly recommended as well, but I wasn't super keen on having to source matched pairs of tubes for rolling, and somebody convinced me to basically double my budget at the outlay. I have to say I've definitely enjoyed my tube amp and got a LOT of value out of it (value valves!), but the little dot I+ is attractively priced indeed.
Get a cheap soldering iron and scrap cables/wires and practice soldering and follow some instructions how to connect/solder point A to B And you are done.I build the 6SN7,6AS7G/6080,12AU7,6DJ8 and C3g adapters(Case,wires and sockets for less than $20CAD).Don't ignore the flea market or electronics recycling place they have plenty of Parts/Materials you can use to make a DIY project that cost next to nothing.
No need for a matched pair of tubes for the LD 1+ you won't hear the difference that just a ripoff.If you asked any LD owner that used the Yugoslavia 6HM5 or any 6HM5 Tall Bottle they will tell you that the Yugo/Tall Bottle 6HM5 is way better than any over price Mullard or Telefunken tubes just to name a few.
Used OCTAL socket for the 6SN7 and 6080/6AS7G adapter $1 each,Bunch of 22AWG,18AWG stranded and solid wires FREE and the used 7 pin extender/tester $3 each.
Used LOCTAL sockets for the C3g adapter $1.50 for the pair.
Discontinued box $2
Used PSU Free from CITY recycling Yard.
Used Hard drive case Free(gut it and turned it into power module case)
Old transformer free,used as a adapter stand for the 6SN7 and 6080/6AS7G for the LD1+ and MK III.
SORRY Ladies and Gents!I know this is not a DIY forum but this is to show others who are intimidated to do DIY project because of the Cost.Using a RECYCLED materials can helped reduced the amount of crap going into the landfill and it can saved you a lot of your hard earned CASH too.If you don't care using used materials and the ugly looks this will work for you,At my City Recycling yard they allowed me to take as much materials i want because i showed them what i did to all the SCRAP that i took from their yard so they know that i put them to good used.So what i'am cheap
