pearljam50000
- Apr 7, 2013
Could you please explain which mod are you talking about?
thank you
thank you
I'd like to point out that your method is also flawed. I have tried this approach and the results were indeed disappointing, much worse than having both drivers set up the same way - this is probably because the two drivers emit sound with different characteristics and the signals that mix in your head are incoherent. The result is very poor imaging resolution and loose bass.
Well, someone got to play devil advocate, right?I'd like to point out that your method is also flawed. I have tried this approach and the results were indeed disappointing, much worse than having both drivers set up the same way - this is probably because the two drivers emit sound with different characteristics and the signals that mix in your head are incoherent. The result is very poor imaging resolution and loose bass.
A lot of what we hear is very subjective - it depends on our hearing, mood, and the gear we're using. Most people here are very happy with the results of the mod, so please let them enjoy it.
thank you
Removing the "sticker" that covers the bass port. Read back a few pages in this thread. It's referenced often, with a link to the original post (in English). That will get you started.
Thanks!
Is it possible to re glue the stickerswithout any damage in case i don't like the sound of the mod?
I'm planning on picking these up, but I probably won't be able to afford an amp for a little. What are these like through a Macbook pro with no external amp?
Just put a small square of tape over the port. You could try putting the original "stickers" back, but I reversed the mod using blue painters tape, and it worked just fine.
I definitely wouldn't suggest them without an external amp. Maybe if you're getting an amp within a week.
To me they're much thinner, more fatiguing and harsh. Strangely the bass seemed ok when I tried it straight from my Clip+.
Back in the day when line outs on Ipods did not exist I double amped a K701 from an Ipod using a Total Airhead. Loved it actually and it still sounded clear.
Generally this isn't a good idea but I don't think it's always so bad.
IMO something like the E17 is the bare minimum. PA2V2 or any CMOY amp should be OK but i've never tried any.
Q701 usually sounds best in my experience with a full desktop amp. For under $130 my favorites are the Fiio E9 and O2.
To me the DAC is just as important as the amp.
Have you A/B blue painter's tape (what brand name?) versus other leading brands of adhesive tapes?
I kid!
I kid!
Listened through few EDM tracks, initial impression is that bass extends a bit deeper with a bit more thump. Feels like drivers are getting more air to breathe, the bass has more body to it but at the same time it feels looser and less controlled.
I kid!
I kid!
After using them for two more days, I now feel that the bass is spot on. I've always thought they sounded too cold, opening the ports seems to have given them a bit of much needed warmth. These are my gaming cans but I do listen to music with them on occasion. Now I just need to do something about these headband bumps.
I think you need some time to get used to the sound as well. It is shocking first time you listen to them after the mod.
About the headband bumps, just cut them. Look at my pictures. Check this as well:
http://www.head-fi.org/t/573055/akg-k702-headband-mods
