Listen to tourmaline, he has good advice.
I killed the performance of expensive equipment for years with the use of active filters, supressors etc on the audio gear. Removing them all one day and using high gauge power cables was a revelation.
Generally avoid power conditioners or filtering on pre and power amplifiers. On digital front ends, passive filtering is a good thing, but it must be passive
- RC networks or chokes. Personally I havent found anything which sounds as good as a 193M choke in parallel for AC high frequency filtering.
From much trial and error here is what I do.
Clamp on ferrites all cables EXCEPT the audio equipment (ie video, fridges, diswasher, etc etc), active power filter strips and ferrites on all computer equipment. This will keep the majority of rubbish, that you are generating, away from the audio system.
Power and preamps - plugged staight into the wall.
CD Player - plugged into one socket of a hefty isolating transformer.
Multi channel front end plugged into a switchless power strip on the other socket with a Hammond choke as the first item plugged into the strip.
Placing a chokes or RC networks on other sockets of the same power line also seems beneficial.
And remember to keep computer equipment as isolated as possible from analog gear, putting filters on it, not the audio equipment.
