- Feb 1, 2011
well with my AKG K518 DJ i can still hear 17khz.
My hearing range is from roughly 21hz to 17khz (using K518 DJ)
Yep.
also lets mention headphones as well. headphones can not and i repeat can not reach 20khz. there is a few that are relativity flat up to around 20khz but most headphones are not tuned that way anymore to make up for bad piercing modern recordings. we have what's called ''modern highs''. what that is the headphone or speaker gently starts to roll-off at after 10khz and just completely drops around after 14k(around the air frequencies). yea some might cause slight peak to give an impression of more ''air'' but that's bout it. very few headphones are even close to being flat in the top-end and past air frequencies. it's a rarity.bottom line don't trust these test tones and get your hearing check the right way is all i'm saying.
so, that's marketing. the sony sa5000 i have with me i'm trying out says it can go up to 100khz in frequency range. can it though in reality? probably not. it's marketing specs,nothing else.
