Just got an HRM7.
Funny that someone finds it bright stock. I find it mid-centric because of the mildly anemic, moderate bass, I find the treble only slightly bright. A lttle brighter would be okay by me, and consider that I'm a long time fan of K701, SR325is, and T90.
Loving the stock sound as is. I may mod mine later when I feel like it.
Overall very balanced FR, minus the upper mids boost (nothing out of the ordinary), and quite tame in cup resonances (this helps make it well-suited to classical music and stuff many would prefer an open-back can for), so indeed a worthwhile monitoring headphone. I appreciate the lack of the awful 10kHz peak most closed-back headphones suffer from. Very consistent and even clarity throughout the audio band from subbass to upper treble, a bit of a rarity there as most headphones boast extra clarity in the highs or mids, usually the mids or just the upper mids, so HRM7 ends up sounding more coherent in a way. Then it boasts very good isolation and supreme comfort.
Awesome deal.
Get bass in a mix to sound punchy and phat through this baby and everyone else will be in for even more of a treat.
Clarity and resolution that competes with the other $200 and under monitoring closed-backs, DT770-250Ω still edges it out in resolution, but not by much. Deep bass that misses 20Hz by a hair, an upgrade cable will be just enough to give it that tiny boost it needs to hit 20Hz if burn-in doesn't do it, I expect.
Edit: now comparing to my K553 which sounds even more tonally balanced, K553 is noticeably more opaque to the sound than HRM7 is, and HRM7's soundstage just makes K553 look more terrible in that aspect than it already is. HRM7's soundstage is far deeper with far better imaging and layering of the sound, fully besting even my modified DT770 in this aspect (whoa). HRM7's soundstage even has a very "natural" feel to it, something I've only heard in my HD25 so far.
I definitely consider this the very best of the $200-and-under closed-back headphones, it just beats them all at everything with very few exceptions as far as individual, specific aspects of sound here and there. My modified K553 is still a really nice "magnifying glass" into bass, better than anything I've heard, even my modified K701 with EQ or HD8 DJ don't quite beat it at that.
HRM7 is now my reference closed-back for the time being. Just wow.
Most audiophile as well as most mixing-worthy in this price range.
Build quality seems also very top-notch. DT770-tier, a freaking tank. If it does have an Achilles' heel, it might be the two plastic blocks that hold the headband together, but only time and use will tell.
