sacd lover
- Aug 31, 2002
Most people dont really understand the limitations of op amps and the fact you cant bias them in true class A for the best sound quality ..... or you would burn them up. Moreover, op amps require large amounts of negative feedback, and the unavoidable sonic penalties that come with negative feedback, to stabilize them to work properly in an audio circuit. But, op amps are probably better accepted here than in most other areas of high fidelity because of their necessity in most portable amp designs.
Op amps dont come close to the sound quality of a zero feedback, class A, discrete design from my experiences .... and yes I have compared the two many times in both headamp and cd player output stages. I get rid of op amps in the signal path whenever I can.
Op amps dont cost enough?
From the prices you see for some op amp based headamp designs they cost plenty .... sometimes more than competing discrete designs.
Originally Posted by Frihed89 /img/forum/go_quote.gif And op amp output stages are "bad" because they aren't sexy? Don't sound good? Don't cost enough? I have seen op amp output stages that sound absolutely lovely in power amps. |
