Uberclocked
- Aug 30, 2014
Does anyone have the email address to Philips Fidelio ? I want to contact them.
http://philips.to/1AcGyTu
You can do a very simple mod with some one-sided adhesive foam cut into rings and stuck to the pads, then impress them on the mounting posts (aligned correctly first; pad seams at the bottom) which will show you where to cut/poke some holes through the foam and vinyl, then mount them, or...
you can apply some double stick tape to the vinyl of the pads, slip the vinyl around the posts and press. I used this method when testing to see how the pads worked, and it was fine. I just preferred the more permanent method, as I knew I'd not be going back to stock. The method with the foam rings is not permanent in the sense that they can't be removed. They pull off easily enough, if you want to go back to the stock pads.
It might sound complicated, but it's not at all. If you decide to try them and have questions, shoot me a PM.
I'm not sure at this point as I purchased it about 2 years ago for an AKG K240 monitor that I no longer use. I remember that the blurb on Amazon US described it as fitting AKG headphones. I hope that helps...
Yea, I guess its the XL size. Thank u!
Does anyone have any good recommendations for a nice case for the x2s?
I don't really plan on taking them out and about but I would like to keep them in a case when I'm not using them.
Yep, I posted pics in the last couple of days and Baycode's did very early in the other X2 thread...(search is your friend)
Ah, good idea. That totally worked, thanks, lol.
I find this whole thing hilarious and blown out of proportion as with everything that happens here on Head-fi. You'd think people are adversed to showering daily to get rid of the extremely small amount of dye that may rub off the pads. Christ.
Thanks man! Returned mind, my 3rd & last unit is on the way, hopefully all goes well.
To those w/ the purple Alien substances, do you get itchiness around / on your ear?
