Baycode
- Dec 21, 2004
Okay so I'm becoming very impatient with the HM5 pads. They have been out of stock for a month now. Only the angled velour ones are available in black. I have the fidelio x2 and I see that the driver is already angled, will the angled pads make a difference in sound quality? What's the difference between flat/regular pads and angled ones?
I advise you to skip angled ones fot the X2 because the X2 drivers are already angled and extreme angle may ruin the soundstage and sound.
Also the non angled HM5 velour earpads are more comfy than the stock X2 pads but soundwise, original X2 earpads are still slightly better.
You may try to wash the X2 earpads. Reported in this and other thread that washing the earpads helps remove the excessive paint (or ink) and softens the earpads. Please check this post: http://www.head-fi.org/t/723025/philips-fidelio-x2/4305#post_11443801
