Equus
- Jan 3, 2007
I'll keep that in mind if the drivers on mine die. ^_^ Or if I destroy them when I inevitably try to mod them.
Get some speaker grill cloth and cover it up. and yes, the little drivers got a surprising amount of bass when you isolate them correctly.
edit: btw, is the frequency response flat for your SFI headphones? I'm interested in knowing the frequency response of these drivers in different housing.
No, they're not flat. The mono imaging on a series of test tones is a bit wobbly, so not only are they not flat, but they're unevenly unflat. Then again, I just did a retermination to a 3.5mm plug, and there's a little bit of funkiness when I twist it, so maybe that has to do with part of it.
I wonder how many folk would be interested in the esw9 - i know I would and I am sure there are more of us wanting to play with a decent yolk for the planar experiments.
..dB
Well I'm ordering them next week most likely. Have some stuff to do first. There's also a lot of 10, but it saves about 2 dollars each and frankly, not worth it.
Thanks Brian , you have seen my wood skills.
LFF, not sealed but ported - so closed and ported tend to give the "best" results.
..dB
BTW, is it the general consensus here that the SFI drivers should be in a sealed enclosure?
