nick n
- Feb 3, 2011
wow . just. wow..
Transformation in full effect. I can hardly believe what I am hearing.
Decided to do a fast one on the Echo TDS-16 black badge variant here. ( ТДС 16 "Эхо" H-16-40C Lvov )
I cut about a 50mm disc of Arctic Cotton and cut it along the radius slightly longer than center.
Stuck that underneath the center tab and butted up the cut ends ( fuzzier side to driver rear ). Removed the stock thin black rear driver dustguard fabric disc
That itself proved a lot better but too peaky.
So I took out that white foam I added a while ago to replace the decayed stock stuff.
[***It shoud be noted that in stock form this is all that holds the driver to the baffle! 4 small rectangular bits of Dynamat at cardinal points fixed that so the driver is held tight and flush the way it should be, when I first got it and went inside to have a look around***]
In place of the foam I added 0.3 grams of Twaron Angel Hair per cup in the rears leaving the stock rear cup black vent fabric to hide the colour and keep it from expanding out the rear slots.
This scale only hits up 1/10's of a gram so I added it to the scale until it was at the low end of 0.4 grams, then tiny bits were taken off unitl it dropped to the 0.3 measurement, so essentially this is on the cusp of a high 0.3 and just before 0.4 grams per cup
Closed 'er up and insanity began. I am not using stock pads but these which are the same dimensions and inner opening.
http://www.ebay.com/itm/2Prs-65mm-ear-pads-cushion-headphone-cover-replacement-earpad-for-headset-2-55-/251649198807?pt=US_Replacement_Parts_Tools&hash=item3a97760ad7
The organicness , it's like the music is alive and I am there. Full. No lack of detail, no shrill highs, everything is flowing together, like liquid. About as simple as I can describe it.
I'll hopefully do this mod for another head-fier in here so they may concur with these findings when they get it done with these exact same headphones. Or maybe not we shall see. I need to know if I am insane or not, beyond normal levels that is.
Bloody fantastic. Long term testing initiated.
Funny story:
A while ago I was out walking around with these at night and all of a sudden something swooped down at me from a building, It was an Owl. I guess it saw the silver(?) and thought they were some sort of shiny mouse/food
I prefer to think it had good taste in headphones.
Funny story:
