Rockcoon
- Feb 23, 2015
hawaiibadboy, expecting to here from you more about SQ today. Maybe more words about differences/similarities between Opus #3 and #2.
Line Out is output through the internal amp.
We designed the headphone output, optical output, and line out on the one 3.5 mm audio jack
Due to this design, it is difficult to make line out to bypass type
My OPUS compare will be with Metal Edition and not the #2.
Metal Edition? Is this Opus #1 Metal Premuim?
The Metal edition has more weight to the sound
The #3 is light and analytical on the lines of the DX200. If you own the Metal version and do not need streaming stay right where you are.
Thanks for your thoughts on the iFi DSD/#3 comparison, HBB! I think it will be a great companion to my Oppo PM3.
Well see how it compares to my DP-X1.
I owned Opus1 plastic, but sold it and now on the market for a new dap. In Opus1 I've missed weight in low end, and wanted for some more treble activity. So #3 probably will not fits me well in terms of bass...
The #3 is definitely more analytical than the #1 both plastic and metal version
That's a god part about #3. If only the bass was stunning
You mentioned about wanting more bass in every DAP thread, so why not just pick a DAP and pair it up with an external portable amp to shape your sound to a desired quality? Or maybe look into cowon DAPs where you can tweak JetEffects?
I'm not basshead. Just saying that in Opus#1 plastic it was not enough for me. Looking for a clean, transparent sound, wint adequate amout of lows, well presented treble, mids, and a bit dominating vocals. It's all there- in Lotoo Paw Gold, but that thing is so expensive.
Can anybody check its transport ability via Optical output? This is very critical.
I don't like how AK DAPs transfer the signal via optical connection – not satisfied with a quality vs USB signal transfer.
What happened to Metal body with CNC textures as the website stated ? U sure it is plastic ?
