ESS ES9038PRO SABRE DAC chip has eight preset and programmable filter types.
How many and what type of filters are user-selectable in Oppo Sonica DAC?
Thanks for the answer.
Posts at the AVS forum indicate no filter selections are available with the Sonica DAC's implementation.
Note that I was one of the Beta testers and can confirm this to be true, but I am not at liberty (yet) to offer any opinions or observations that have not already been published.
According to the thread from AVS forums, it seems you have to physically change the inputs from the unit. Can anyone confirm this?? Seems odd at this price point not to have a physical remote or ir sensor. Smartphone controls are great, but having to get up off the coach like an old CRT television seems odd
Already discussed at the AVS thread and/or revealed in Oppo's published specifications, the
Sonica App allows selection of USB Storage (an HDD or flash drive) at either of two USB-A ports on the Sonica DAC (or at a Sonica speaker), Aux-In, a Bluetooth source, Network playback, or files on the smart device itself, plus Tidal or Spotify, if you have subscriptions.
Selecting an input from the Sonica DAC's USB Type B jack, Coaxial, Optical or Aux-In jacks, is done at the DAC itself, which overrides whatever source may be selected at the Sonica App, until you again select one of the sources handled by the Sonica App.
The question becomes: How often are you going to find yourself switching between USB, Coaxial or Optical inputs (without a remote control) vs. any of the several sources that can be selected via the Wifi-connected Sonica App (which includes the ability to select the DAC's Aux-In jack or either of two USB-attached drives)?
So I've been using the Sonica Dac for 5 days now. I'm confident that there are some improvements over the well implemented ess 9018 Dac in my Burson CV2+ amp.
There is more depth of field, less glare on the top end and a bit more snap to my music. It took a few days before I caught on to these differences as they a subtle, yet quite noticeable.
That's good news, that you are hearing less of the somewhat infamous "ESS glare" heard with many ESS9018 DACs.
Are you finding the lack of remote control for USB, Coaxial and Optical input selection, to be an issue (at least for your needs)?
