- Oct 14, 2013
Sometime hiss, distortions can just come from an IEMS or headphone...it is not always the sources faults :-/
I'm not sure if this is a normal Android thing, but when the screen goes off (which I assume I can adjust how quickly this happens in settings) you can't slide on the screen to waken it. I read above that this requires the use of the power button. Is this an Onkyo thing, or an Android? It has to be an Onkyo thing, I can't imagine any phone needing this action to wake the screen.
That is a slap in the face on AK rip-off roflmao...
You need to unmount the sd card and use a card reader. Or better download the id3 tagger for android and cover art downloader app
First, and really first, what exactly are the third party apps yourselves and others are suffering issues with?
"...every app..." and "...every one I tried)..." isn't helpful, so please list your the apps you've tested.
Please also tell us your setup; headphones, and if you are using external equipment at all (DAC, amp, DAC/amp).
Second, I have had zero issues with any and all third party apps I have used:
- Onkyo DP-X1 Music App,
- Tidal (I no longer subscribe to Spotify),
- YouTube,
- The Room 3 by Fireproof Games (amazing sound effects and music for this game, though I prefer my 2K Samsung Galaxy S6 Edge Plus screen over Onkyo DP-X1 720p screen),
- BBC iPlayer,
- BBC iPlayer Radio.
I believe my friend, @scootermafia, has had, so far, a trouble free experience with third party apps also.
It is my firm belief that it's a System Level Android settings issue.
Run the app that you've got an issue with. Then go to Android Settings > Sound and Notifications and record all the settings as is.
Or, in a worse case scenario, if you are running apps off the MicroSDHC/MicroSDXC card (or downloading album's to the card) and having cracking issues or similar, then the cards could be faulty. You'll need to do a memory check if this scenario is the case.
Finally, if you are using unbalanced SE headphones or equipment and AGC is on TURN IT OFF. This might also be a reason as AGC only works with balanced connections, and third party apps might have a hissy fit with AGC + SE.
Not sure if I can troubleshoot today but I will try, or another Head-Fi'er can step-in.
I have a full set of Westone star tips I've just found unused in my drawer
This issue has been reported at least 3 weeks back and has yet to be resolved, and was also one of the first things I checked upon receiving my unit.
The distortion is apparent on certain tracks - just because one does not hear it, it does not mean it is absent.
In fact, the effect is reproducible!
As I have mentioned at least twice before, there is a test track available that headfonia has graciously provided us with - I have linked to it here: http://www.head-fi.org/t/780642/onkyo-dp-x1-dual-sabre-dacs-balanced-sabre-btl-amp-mqa-dsd-256-android-5/3225#post_12247961
The distortion on this track is apparent not just through my IEMs, but even my speakers!
If you are in disbelief, do try it out yourself (compare between stock app and any third-party app!)
After all, hearing is believing, if my words alone are insufficiently convincing.
Again, I do strongly suggest you try it out yourself before offering your vehement critique.
Are you sure the track is not distorted itself ? I am very curious...some track were mixed, composed to have let distortions run in, and in some lower tier gears you may not hear it much because it is forgivable and not as detailed...however on good revealing gears it will show.
Hang on so are we sure that the onkyo does not support native DSD? All the brochure material states that it does!?
Woah woah woah!
There was nothing vehement in my post!
I too have read every page of this thread but I still stand that those previous posts do not show enough information on what settings, equipment, hardware and specific apps were used!
My above post was strictly so that I myself can retrace your footsteps, see if I can reproduce the issue, or troubleshoot for you!
I do have a more upfront way of speaking (it's a British thing) but my intonation was not acidic; I honestly posted as much as I could so a proper, peer-to-peer testing and troubleshooting can occur.
This forum is about helping one another after all.
Forgot to ask which music was played also, though @Zenifyx has linked a nice track to test. Will do a bit later, but I want to try and replicate the conditions thats causing the issue as best as I can.
I have also not read if these issues has been reported to Onkyo directly or not either...if not then that's another step that may be needed too.
- slightly disappointed about amp section as on high gain with my apple earphones, im already between 115 - 122/160. So i dont think the Onkyo has the humpf to drive any difficult headphones.
Vehement - showing strong feeling; forceful, passionate, or intense.
Your words showed a firm belief that the fault was in the user settings, and not the player itself. - hence my use of the word.
The previous posts have already provided a set of conditions for reproducing the distortion.
Specific settings, equipment, and hardware were not necessary to reproduce the effect, thus not stated.
The specific apps were stated in previous posts, with some searching - UAPP, Neutron, JetAudio, GoneMad (4 apps should be a sufficient to determine that it isn't a specific app fault, and most, if not all players use the standard Android API for music playback anw so an exhaustive list would be unecessarily tedious)
Not sure if Onkyo is aware of the issue, but I think someone stated awhile back that the Japanese community was aware of the issue - hopefully they gave feedback to Onkyo.
