memepool
- Mar 24, 2004
It can often sound a lot different to a commercial release depending on how good your equipment is and for the reasons mentioned above, ie you want it to sound good on your hi-fi system whereas if it's pop music the guy mixing and mastering it is being told to "make it louder, give it more punch, more sparkle" and testing it on a load of different sized monitors to take the best overall mix which is usually to the lowest common denominator ...etc etc.
I don't think you can reasonably claim that engineers were better back in the 50's or 60's, that's just nostalgia. There are too many other variables involved.
There are talented people in every era, at least today the playing field is flatter so anyone with a computer can make a cd, as you say and also release it online. This is equality of opportunity, the downside of which is that there is so much music being made that the market has completely fragmented and the industry needs to change to reflect this new reality, something it is struggling to do.
Records made today can be every bit as good as any ever pressed, it's a boutique industry now which is increasingly about quality over quantity where a vast amount of stuff is being pressed on 180gm virgin vinyl.
This seems to contradict what you said earlier and I am still not sure i agree. CD hasn't changed or evolved because the redbook format can't evolve it's set in stone in 1983.
Whereas a record from the 1950's can sound better today than it possibly could in the 1950's because record players have got better. Yes there were excellent record players made then like the Rek-O-Cuts and Garrards but tonearms and especially cartridges have developed and anyway most people were listening on a Jukebox or a Dansette back then.
Undoubtedly there has also been some progress in CD playback technology but because it's a digital system it is necessarily fixed in specification and therefore limited. The difference between a basic record playing system like a dansette and a modern good quality table like the VPI scout is far far greater than the difference between a Philips CD100 and a Meridian GO8 although the "software" remains the same.
What evolved in the "software" is that with CD being the major format, engineers stopped mastering for vinyl and adapted their methodology to reflect the different characteristics of CD.
Recording technology hasn't really got all that much better since the 80's. Yes higher resolution digital gives a better recording but as I said earlier there are not that many things actually being mastered beyond 16bit 48k DAT quality becuase that is still what the majority of Protools suites are running at.
Certainly Microphones havn't improved any and the latest trend as in Hi-Fi has been for Ribbons and Valve pre-amps, 50's technology.
Originally Posted by bigshot /img/forum/go_quote.gif When I digitize an LP to CD, it sounds *exactly* like the original record. Format isn't the issue. Also, there was considerable noodling required to get an LP to sound as good as its master tape. The vinyl format isn't responsible for good sound, the quality of the engineering back in the 50s and 60s was. Nowadays, anyone with a computer can record, mix and master a CD. And a lot of engineers just don't have the experience that they had back then. |
Originally Posted by tourmaline 18 bits sounds better then 16 bits, 20 bits sounds better then 18 bits and 24 bits sounds better then 20 bits, it's that simple...old and dew cd's the older one recorded with older equipment and the new cd with newer equipment, yeah of course i expect the new one to sound better, evolution of recording gear... |
