raoultrifan
Soundstage increased a lot, better bass extension, trebles sound now with much more details...etc.
Kidding, of course...couldn't help myself, sorry.
Short answer: NO, I wasn't noticed any improvements, but it would probably be very difficult to improve something to Objective2 with ease. After all, O2 is measuring perfectly with sine-wave signals on inputs and I'm glad after doing the above mods I was able to make it measures almost perfectly with square-wave input signals too.
O2 is lacking a more powerful output buffer to drive planars or really low sensitive cans, otherwise...it's the perfect headamp for most headphones out there. However, it can easily drive my Fostex T50RP mk3 planars, but also the 600-ohms Beyers, so I really have no complains.
Maybe in an A/B test with 2 identical O2's I could be able hear some difference between my modded O2 and the original O2, but otherwise...my ears are not feeling a really difference, sorry. However, from my previous experience with the MUSES01 and 02 in Voltage-gain stage, but also with the Burson SS V5, I've notice a bit of increase in soundstage, but be aware of their price.
Also, the background noise is a tad lower now with the OPA1652, tested with sensitive cans (Beats Solo2 and AKG K550), O2's gain @ 3.7X and volume knob to the max (nothing connected to O2's inputs!). Also the DC-transients are lowered too when powering ON and OFF the O2. In case you want to try SOP8 opamps, feel free to follow https://www.head-fi.org/threads/make-yourself-soic8-to-dip8-adapter-56k-warnings.89714/ or similar threads. Personally, I was using DIP8 socket instead of the small PCB + pins and I had the OPA1652 mounted on top of the DIP8 socket and get it soldered (some small wires were added too, also flux was used).
