thecrow
- Oct 18, 2014
Yes. It's changing the sound.
And I enjoy it for it.
Now I've come across two different opinions: one of that the DAC being the least important link in the chain (as long as it does it well) up until you reach the $1k mark. As I've also read that bumping yourself up from an ODAC to an uber Bifrost (both upgrades) gives you very very slight audible improvement for quintuple the amount. This side also says that the AMP plays a far more important part in synergy with the headphones. Literally piling their heiarchy as thus: Headphones > Amp > DAC.
The second are on the solid ground that even a $100 difference is a night and day difference, and is just as important as the headphones themselves.
The middle ground doesn't seem to appear.
So my one question would be: by pricier, how much pricier are we talking about? I've seen the same amount of reviews saying that the ODAC is just as good as the benchmark DAC 1, than the reviews saying otherwise.
Yes, that's all fine and dandy, but you're missing the point of the O2/ODAC: it's to simply provide a sound that's as unaltered as one could get. So while it's true tubes provide a different sound due to different harmonics (easily visible in square wave tests), that's not the point of the O2/ODAC. If you think that 'organic note decay' is better with other DAC's, more power to you. But it's an addition to the source in the end, which is contrary to the point of the O2/ODAC.
I've listened to quite a few DAC's though, and I struggle to hear the difference unless there are additional 'bass-boost' filters. Maybe I lack the golden ears that you have, but the whole point of DAC's isn't to alter the sound, but to provide the best (ie. accurate) conversion of digital to analog. Anything else is contrary to the point of an ideal DAC. That being said, if you don't like that, fair enough.
Thanks for your clafication, I have always itched a bit for some DAC upgradetitus but have been reading a collection of contradicting points of views. Another consideration for myself is that I purely use USB as a source, therefore I cannot help but see additional input choices (TOSLINK etc.) as unnecessary addition to cost, which seems to happen often on many of the higher priced DAC offerings.
For now I am using an ODAC and an amp (DIY SeNNator Project) filtered specifically to balance out the HD650, and it's a sound signature that I enjoy thoroughly. The O2 I have, I now use with a modded pair of T50RP's, it's uncanny how well the O2 works with those headphones.
My wallet can rest a bit longer.. For now..
I see the ODAC/O2 Combo advertised a lot with the DT880's being shown. I'm guessing there's a reason for this, and that the DT880's make a pretty good pairing?
Well, I have exactly that pairing and it sounds great to my ears! With the DT 880s, it brings our the details in songs which I never knew were there even after listening repeatedly in the past. They don't seem to hide micro or macro details but present it there for you.
With the HD 600 and O2/ODAC, it brings a smoother sound with macro details being pulled forward and I enjoy it a lot and while micro details are present but you need to watch out for them.
It's like if you know its there, you can hear it, but if you didn't you might just pass over it without noticing.
I'm sorry for a lack of a better way to describe them.
In both cases, with the O2/ODAC at least my mind is at ease knowing that it's 'transparent' enough to give a fair comparison. And that, IMO, is what my amp and DAC should do. Either way, I love both the DT 880 and HD 600 on my O2/ODAC.
I hear the HD600's are more open than the DT880's. Maybe that's why it's easier to miss micro details when listening to them?
What kind of USB cable does the O2/ODAC Combo come with and need? Is it USB to Micro USB, or something else?
Thanks.
Thanks.
It comes with it's own cable bundled with the ODAC. That you don't have to worry about.
If you're buying the O2 and ODAC as separate unites you will need a 3.5mm interconnect, or RCA to 3.5mm or Dual phono RCA depending on the type you bought.
If you're buying the O2/ODAC combo unit, you only need the usb cable that came with it, and the wallwart.
Of course, just as important: your headphones.
I was thinking about possibly getting a better cable for it though. That's why I was curious about what kind of USB cable it is. What kind of connectors are on each end? Is it a basic USB to USB, or USB to Micro/Mini USB? And yes I am getting the combo.
