thecrow
- Oct 18, 2014
@thecrow
Little confused about the sentence, "Having said that....I have found, for me, the odac is a fair/ok dac for its price but the O2 is a great neutral/transparent dac well priced too. I'd recommend it to my own mother easily."
You said the O2 is a great neutral/transparent DAC, but I thought the O2 was an amp? Are you saying the O2 is an awesome amp, but the ODAC is only decent?
I wrote "having said that" as I just wrote before that to essentially take opinions with a grain of salt.
As others have said nothing here is as good as people make it out to be and never as bad as they say either. Views all have some preferences or are tainted with personal biases. norhing beats having a listen yourself.
My opinion is the O2 is very good. If I was in the same position gain I would buy the O2 (on its own merits) and then buy the Odac (Almost by default) to make the pigeon pair. I'd still be happy with that combo. If I just wanted a dac I'd probably look around and compare others to the Odac and spend another 2 weeks of constant reading here to make a decision.
I found the Odac to be quite similar to the dac in my fiio x5. So quite reasonable and fair.
Odac 7/10
O2 9/10
As a combo 8/10.
A great combo at a good price.
