orthikon
- Aug 16, 2007
anyone using the headphone out to use for active speakers?
Originally Posted by ledzepberkeley /img/forum/go_quote.gif Thanks for all the feedback everyone, this site is so helpful |
Originally Posted by krusty20874 /img/forum/go_quote.gif Did you ever get the Nuforce? I have the DT770s as well and also contemplating between the Nuforce and the D2. |
Originally Posted by kazsud /img/forum/go_quote.gif What does the -/+ switch do? |
Originally Posted by dimisam /img/forum/go_quote.gif I am planning on buying a Denon D2000 together with a Nuforce icon mobile amp to power it (looking for a reasonably priced amp because my wallet is gasping for breath). Do you think this amp will be suitable for the D2000? |
Originally Posted by kazsud /img/forum/go_quote.gif Is there a way to turn the dac on and off? |
Originally Posted by kazsud /img/forum/go_quote.gif Ok so the DAC part only works while plugged in a usb port? Sorry i am a newb Trying to track one down as we speak and willing to drive to nyc (from philly) to get one |
jwbrent;5185761 said:I have over 250 hours of play time on the Icon Mobile now with maybe 50 of those hours on the DAC section. Since I use the IM as a headphone amp only, I only wanted to get some time on the DAC so I would have an idea whether it sounds better than straight out of my iBook. It does.
How do you use it as a amp only?
Originally Posted by SpudHarris /img/forum/go_quote.gif The set up looks sweet. I love the case what is it and where can I get one? It'd be great to hear back from you..... |
kazsud;5467431 said:Quote:
Okay, this is the way it works...
When nothing is connected to either of the headphone outs or the USB, it is off. This is the only state in which it is totally off. There is no power switch; as stated, the recessed +/- switch is for adjusting base gain to match the sensitivity of your headphones.
When connected via USB, it charges. It is also in DAC mode, and shows up like a soundcard in your computer interface. Simply connect headphones to use it; the volume dial on the side is best for controlling the volume, just leave volume maxed out in the computer and your software. The line-in does not work when connected via USB, so if you wish to use a device via the line-in, you must disconnect it from USB (hence, you cannot charge while using the line-in as your source).
When not connected via USB, and something is connected to the line-in, it is still off until headphones are plugged in, at which point the amp is activated and in an on state. I generally recommend always turning the volume dial down to zero before disconnecting or connecting headphones to the amp. As long as there are headphones connected and USB is not attached, the amp will be drawing down its battery, regardless of presence of input source.
That being said, I would just like to mention that fully charged, my Icon Mobile has a big enough charge that I have yet to use the battery up in a single charge session; however, I don't know if I'm alone in this, but I find that the Icon Mobile very quickly loses its charge when not being used compared to anything else I've ever owned that has rechargeable batteries built in. In other words, say I charge it overnight tonight, I can pretty much use it the entire day straight tomorrow, but let's say I charge it tonight, and I disconnect it tomorrow morning, but then I don't use it for an entire week, then I decide to use it, but I don't recharge it first, chances are, after a week of sitting idle, the amp won't even activate when I attach headphones, such as it has completely lost its charge in about a week's time without even being touched, after a full charge!
-Ed
