Originally Posted by Aevum /img/forum/go_quote.gif
the main problem with rotarys isnt reliability, it is somewhat of an issue becuase it runs at higher RPM´s, therefore oil changes are more frequent and maintenance windows should be closer,
the main issue is that wankel rotary engines tend to have the fuel consumption of a piston engine about twice the size, which is the original reason why when mazda tried to export their first gen rotaries to the US and europe, it was just during the 1970´s oil embargo, and they didnt sell very well,
running at higher rpm's is not an issue go look at honda engines that rev just as high and run for stupid amounts of time without issues
sure an engine that's run harder will cause more wear on oil resulting in it needing to be replaced more often but the main issue isn't with wear on rotary motors it's the fact that oil provides lubrication for seals which is more important than being rev'd to 7-8k all day long
Originally Posted by skyline889 /img/forum/go_quote.gif
I have never known an FD (Don't know any one who still runs an FC) owner that did not have reliability problems. The FD runs notoriously hot and if you've ever pushed your car hard or been to a track day, the 13B will give you problems no matter how well you take care of it. Because of the way the Rotary is designed, it has a laundry list of problems just because of the way the engine is designed, couple this with the fact that the FD was poorly designed in terms of cooling to begin with and you'll definitely have fun if you ever do anything more than drive from point A to B every morning. Overheating, pressure loss, carbon build-up, and blown apex seals, are just some of the problems that most of the guys I know have run into. While there are less things to potentially go wrong on a Rotary since there're less places where something can go wrong compared to a standard piston engine, it doesn't mean that less things will go wrong.
sure there are known issues but it doesn't necessarily make the car unreliable. if it's a known issue do something to address it. why do you think most fd owners upgrade their cooling systems why because it's a known issue with them so they do something to PREVENT problems from occuring
i drive from point a to b and have plenty of fun with my fc and if i did I wouldn't go street racing and then post when i crash my car only to edit it later on
but to address most of the issues you talk about
overheating - dealt with through preventative upgrades as pretty much anyone who is going to push their car will do or else it really shouldn't be a problem unless your car is seriously running poorly
pressure loss - i'm assuming your talking about engine compression? if so every car will lose compression over time it's just the nature of things wearing down
carbon build up - entirely dependent on driving style, severity can be controlled but still the engines life is finite so it will eventually die but depending on what you do you can decide when this will happen
blown apex seals - try getting a decent tune or not running ****ty gas. sure apex seals will blow (engines have a limited life span) but prevention through regular maintenance (yay oil changes every 3k) will prolong the life. go read up on some rotary boards to see why apex seals blow usually it's related to poor tunes or bad fuel
but yah
the rotary is a great motor and will last just as long than it's piston pushing counterparts so long as the owner takes care of it (which from what i've read you didn't on the one your parents bought you)
